Engine Questions
Hi
iv got a mk2 squareback atm, its a 1litre and when its gets put back together thats what will be going back init, for a bit anyway.
I've thought about gettin a 1.4 abd block, with a gt head
would that work? is there somthing better
i was also thinking about making a turbo, and having webbers???
can it be done, what would i actualy need, a list of some sort would be good :)
also where to get the stuff
cheers 8-)
  • Replies 10
if your planing a 1.4 conversion i think you should source a donor car that way you will have all you need (electricks etc) or you could land in a big mess with it
best of luck mate
hmm never though about that
think id need a gt donor car, but if couldnt bring myself to rip one apart id have to fix it up lol
Its possible to blow compressed air into carbs,been done in the past (but not too reliably..). I heard from someone that its possible to blow into bike carbs too,but any carb would need substantial modifying to work in such a situation - as they're designed to work using intake vacuum,and that vacuum is replaced with pressure with a turbo - hence the need for high-pressure injectors.
Id look towards converting my bike carbs into throttle bodies myself,by fitting fuel injectors into a custom manifold for them (thus running the carbs dry,with a throttle position sensor on them to operate the injectors via a suitable ecu,such as one from a bigger n/a engine). Or if you're gonna go down that route,you'd just use bike throttle bodies,and said suitable ecu and injectors.
I can think of another way that might work,but its too good to share - i might try it myself first. :D
well thats no fair :(
so throttle bodies could work better?
what would engine be if money was no object and you had a 1.4 block and 1.3 gt head lying about??
lol
It depends on driving style and where the car will be used..
I'd personally go for a 10,000rpm 1.3 on throttle bodies.
so just a gt engine? with throttle bodies?
and some other tuning?
or is there another 1.3 that you mean?
Yeah, but once you've got it at relative reliable 10,000rpm there won't really be any GT engine left.
ok so i buy a gt engine...
what would need doing to get it to that stage
Strapping everything you can to an engine isn't always the best thing you can do!
no i know I'm just trying to get ideas tbh
