Renault Megane Coupe 1.6e £350
selling this renault megane coupe 1.6e
9 month MOT
tax'd till end of month
possitives
The car has recently been serviced, has had few new parts that i will list. the car has been used to get to and from work which is 5 mins down motorway, really good on petrol, it has 9 months MOT. Tyre's are all good, the rears are quite new (4month). exhaust was replaced a year ago, spark plugs changed last year. most recent new parts are:
* Wheel bearing rear (not sure what side)
* Coil pack
* tdc sensor
The bad bits:
* The coils went a couple of months ago, they was replaced with band new ones and a new tdc sensor. but unfortunately because the car was left for a month the key fob had seemed to reset itself (i think) which means the immobilisor could not be turned off. i have got the override code which we are still using to actually start the car. (you type this in before starting)
* The car jerks at slow speed and makes a slight noise when the car is decelerating (but the noise stops when the clutch is pressed) i personally think its the clutch but I'm not a mechanic.
* the suroof does not work due to a leak it had
* body work: you can see the dents in the pics (dent in bonnet that you may not be able to see in the pic and tape on roof that used to stop the leak)
although most the description is negative the car has been good to us but now needs some work doing. the car is still been used daily.
£350 no offers
  • Views 346
forgot to mention its location,, Elsecar,near Barnsley area thanks.
CAR SOLD ...
TO ME LOL :)
Awsome buy :)
