Cheap Tyres?
i need some low profile tyres for my alloys there 14" i just need them low profile I'm not fussed about the make just want the cheapest deal as possible anyone no where i can get them really cheap??
cheers
  • Replies 27
  • Views 2.9k
you are asking for trouble with cheap rubber in this weather chap - £20 extra could be the difference between ditching it and not...
Dave
dnt worry m8 i drive a 1l theres no power to ditch it :)
wen it comes to measurements what in terms of low profile is really small and what is big?
Fair enough but power aint needed to ditch a car - holding too much speed into a corner could though so just take it easy on shit tyres...
8-) - we want the polo and you around for xmas!
lol dnt worry mate I'm not a bad driver :p
what tyres would you recommend?
Tyre Sizes are in 3 parts
195 - the width of the tread
40 - the width of the sidewall
15 - the diameter of the wheel
low profile normally means reducing sometimes both the tread and sidewall widths, but most times it is safest to simply reduce your sidewall width.
Instead of using a 195 /50 /15 a lower profile option would be a 195 /40/ 15
Hope that helps.
Dave
you could try race and road...they seem to be quite cheap
on another note...dusnt matter how good a driver you are..circumstances predict the outcome...not always the driver
be safe
stopping distances are also effected ...aint worth belting a lorry up the back for a few quid
decent brand tyres really do make a big differance to how the car rides and road noise etc
dont like to preach , but see how much differance it is to upgrade to a known brand vs ditchfinders
Hope that helps.
Dave
The 40 in the above means 40% of the width so 40% of 195mm. So a 205/40 will have a bigger wall than a 195/40. Hope that makes sense.
Don't scrimp on tyre mate, they'll all that connect you to the road. makes no odds how big the engine is.
OP
Depends what width your wheel is
I got 165/50/14's on my p-slots thats a real good size for me
Low profile the width of the wheel is average like a stantard VW alloy
ok so I'm going to look into a fairly decent make so r falken any gd? wut is really cheap i would say cheap for me would b 120 for 4 tyres?
i sort of understand the sizes now so does it mean if i get
195 - the width of the tread, this means that if i get a smaller on this i get stretch?
40 - the width of the sidewall - the general size of the tyre so is 45 any good?
15 - the diameter of the wheel - i understand :)
cheers everyone, I'm going to try and spend a bit more on the tyres now.
What's the width of the wheel? Also is the car lowered? If not then a to low profile tyre will look rank, you need to fill the arches a little.
I'm not certain ill look wen i get hme, i think I'm guna drop it 60mm it will b dne so i do need low pros but wut would u recommend with low pro? i need cheap suspension and the more i spend on tyres the less ill have for suspension if u understand? :)
I used to put cheap tyres on the back and expensive tyres on the front,purely to give me the tail-happy handling i liked. Turn into a corner,lift off the throttle,steer into opposite lock - and side it like a dancer!
And that,even when the Yoko's/Avon's/Goodyears on the front were bald,the cheap tyres on the back were new,and it was wet. Thats how much of a difference you get for what you pay - compound is everything. Which confuses even more,because i find Michelin well overrated for grip. But they last like no other tyre,so there's your moneys worth.
I dont know much about the 'intermediate' brands. Some say Falken are alright,alot seem to rate Kumho's - but i'll never use the latter again,i found them unpredictable.
can i ask how much u pay for your tyres and wut do u see as cheap?
I'd pay no less than £160 for a set of 4 tyres.
they r 195/45/14 well thats what I'm after and 160 is the cheapest i can find for a set of 4 falkens without p&p :\
www.mytyres.co.uk are pretty good but obviously you need to get them fitted and balanced locally so factor that into the price :)
Edit: Fuck it, totally missed the point!
Edited by Leigh
If they do the size your after then Hankook are good on a budget. I used these on my mk1 fizzy and they were ace.
They describe themselves as a premium tyre with a budget price.
There was a Which report after I bought them and they were in the same legue as Conti and Pirelli for grip in the dry!!
Not so good in the wet but saying that they were as good as Michelin. I don't rate Michelin at all though. Too hard compound.
i know this isnt my topic but i just got some 6.25inch width and 15inch diameter alloys what tyres would you recommend i would like them to be low profiles thanks liam
For the love of god don't scimp on tyres. Trying to justify getting shitty rubber by saying "I'm a good driver" and "It's only a 1.0" is just about the silliest thing I've never heard.
Tyres are what keep you in contact with the road, not your posh wheels or your extra low trick suspension, so spend an extra few quid and get a decent set!
www.tyre-shopper.co.uk..got mine from there, cheapest place I ever found!
