Seat Belt Tensioners... I Think
I've got my car lowered about 60-70mm which makes going over speedbumps a bit sore at just 10mph.
Anyway, the council hae started building new speedbumps on a long flat stretch of road. they're at the stage where the road drops about an inch then goes onto the bump then the same going back of again and they're not marked. It was dark and I hit it at 40mph and it felt like I went up a kerb! I felt my seatbelt pull me back into the seat and there was no one in the passenger seat. The passangers seat belt is now stuck in position and I cant pull it down.
Why is this and how can I solve it?
Thanks Phil
Edited by phildi88
  • Views 885
sounds like the seatbelt pre-tensioners have fired.
You'll be needing new seatbelts mate as they're one use only.
Sometimes the airbag light comes on the dash and you'll probably notice fraying on the drivers belt where the belt's been gripped.
Sounds like the above, although it is worth checking that the seatbelt reel is sat level, as if it's off-centre, it will lock the belt.
