Low As Poss For As Cheap As Poss!
hi guys iv got a mk3 polo on 14in clio wheels with 60 profile tires n about a 60 mm drop with a grinder :-D lol but its still far too high for me!!! thinking about getting the arches flaired but this is a very cheap project so need to do things as cheap as poss n would like some camber on the front!! any suggestions would be great please!!! will put pics up soon lol
  • Replies 34
  • Views 3.2k
60 profile? Of what? Not 185,surely? The tyres sound massive,you're gonna have a problem getting it down with those.
Camber isnt adjustable with these cars. Not cheaply,anyway.
The route to getting it down safely IMO is an 80mm lowering kit,then cutting off most - but not all - of the springs preload length on the bottom end of the front spring,then as much as you want of the top end of the rear spring (up to preload) to get the stance. Some dont agree that any spring cutting is safe though,even if you keep within the preload.
cutting springs is a shit idea from the outset tbh mate, If your gona do something do it properly IMO
you would want to watch out cutting the springs mate, police around my area are pulling lowered cars and jacking them up on the roadside, and if your spring falls out "bye bye licence".you'd be better getting a set of lowering spring's or even some cheap coilover's.
paul.
philJ coilies are cheap enough, can sell them on when your done and make some money back too probly
hi lee
paul.
and 500 quid isnt cheap trust me haha
how about a set of philj's coilovers?something like 250 quid aint it? :lol: well thats what i hope youre referring to?
paul.
Its a darn sight more than that if he means his car is a MK2F..
:paranoid: oops never spotted that :paranoid: sorry.
paul.
tbh 80mm kit plus lowering top caps is low enough!
Nout wrong with chopped springs. If you chop them enough the police won't be able to jack the car up at the road side :)
i tell you what lee
get lower profile tyres? jobs a good en
Lower top mounts take the height out of the preload - so you might aswell just chop a coil from a 40 or 60 spring instead. But use PhilJ shortened shocks by all means,so that the spring doesnt fall out when the community nerds jack your ride at the 'side.
Chopped springs for the win. I chopped mine on the Sierra...
Don't even fall out at the back...
Or front...
It actually passed an MOT with those, and they took the front strut off! I have fitted new Gmax lowering springs on the back since, and the ride is 1000x better, even though i chopped them too.
Chopping is fine, but the ride will be absolute shite. Get some cheapy lowering springs (i got the rears for the Sierra for £11 quid on ebay) and chop those, the spring rate will be way more appropriate.
Edited by Nev
/\ thats a wind up surely
cable ties!
at least you cuda gone to jubilee clips :lol:
Pimp wheels on the Sierra though!
cable ties!
Haha, seriously, it passed an MOT like that. They were only there so they didn't fall out when fully extended. The rear ones don't look like that anymore, the current ones actually fit!
The front is ok though, same story again.
Yeaaaaah!!
Spring choppers unite!!
Yeaaaaah!!
Form of:
I made the mistake of chopping it then trying to pull it out. Not thinking that when its been glowing red for the past 5 mins it'll still be hot. Ouch :(
doesnt say much for the shonky mot place!
cable ties!
Personally,i find that lot shocking. In fact,its that kind of butcherism/bodgism that gives the trimming of springs a bad name.
Removing some pre-load,and holding scrap metal together with cable ties,are two totally different things - please dont confuse my suggestion with those horrific photos.
Every time you cut your springs, a kitten dies. :p
Just to prove i'm not that bad, i did replace with propper ones shortly afterwards:
The front ones are ok, i just don't want them falling out, that would be bad.
Edited by Nev
This might be a stupid question but why hasnt anyone tried to heat up a coil on the spring to the point it collapses on to the other coil (so there is one coil closer to the other) so you have a shorter spring? at least then the spring would sit properly in the mounting. shurley that would be a easer option than taking a grinder to them?
