Door Trim Removal
DOES ANYBODY KNOW THE BEST WAY TO REMOVE THE DOOR TRIM OFF A MK4?
THANKS.
  • Views 1.5k
u mean the external rub strip of the internal doorcard?
Pull the handle off the inside with a screwy, and then undo the 2 big ass screws, pop the window winder off by pushing the circle bit away from the handle, un screw the door pin, pop the wing mirror cover off, and same again with the mirror adjustment control, go round the outside with a screwy popping the trom off it's pegs and then pull it away over the lock and past the door handle!!
2 minute job!!
I mean the outside rubber strip lol.
Hair dryer it all for 10 mins, whip a credit card/body filler applicator under it, slide it along in a sawing motion, then with the left over glue, get a rag, keep dipping it in petrol and rub the f**k into it, then scrape the glue off with the credit card or similar. Repeat the petrol and scrapping bit and then T Cut it!!
Sweet for that mate worked spot on.
instead of the hairspray u could also use a hair-dryer for heating the glue.i wouldn´t use a credit card (or similar stuff) but a strong fibre.
just take your time...and don´t stress :D
good advice there was jus about post that topic myself. gonna been an upcumming job
