Good, Strong, Full Blend, Recently Serviced G40 G-lader For Sale
I'm now stripping my engine down to convert to turbo. The main thing I have for sale is my trusty G-Lader. I had initially planned on keeping it but I just simply can't afford to, I need to money to buy other parts....
So for sale, I have a G40 G-Lader. It was serviced by Pitstop and ported to their Full Blend spec between 3k and 4k ago at a cost of around £500. I have owned the charger for nearly five and a half years (was jabbasport stage 4 spec before PSD worked on it). It has always made good boost and been strong, it has never ever blown an oil seal. Always makes a good 15psi boost all day long on a 65mm pulley. Since the full blend I have always ran it on a stand-alone oil supply and regularly treated it to proper PTFE grease, always well looked after.
Also included is the ported outlet elbow which was normally ported as part of the PSD full blend. I will also throw in a nearly full tin of the proper PFTE grease to keep it in good condition for years to come. I can include a stock g40 twin v-belt pulley at no extra cost if you want it.
I will get some photos of it up tomorrow.
I am looking for £500 for this which is a bargain really considering the rarety of these coming up for sale and the fact you wont have to shell out for servicing and porting as you do with a lot of 2nd hand chargers.
paul@polog40.co.uk
cheers,
Paul.
  • Views 312
forgot to say, I'll also throw in an inlet blanking plate which is necessary if you are running with the boost return pipe removed. :grin:
possibly sold....
