Will It Fit....
Will the grill surround from a mk2 ibiza fit onto a 6n? Or will i need to change the headlights aswell? Maybe even bonnet? If it would, then would it actually look any good :lol:
  • Views 900
Its all wider,the Car is wider,its just styled to look the same shape. If you're up for chopping,gluing,smoothing and painting the plastic,then I'm sure it could be done. Alot of work,relatively.
Fair enough..Ill see if i can find a cheap one at a scrappys first :lol: If not then ill just go badgeless :p
