Problem With Fitting 6n2 Leather Drivers Seat
I picked up some leather seats off of bbspolo the other day and they have all fitted in fine except the drivers seat.
I drive a 6n 16v and the seats have always been awkward with the runners going forward and back, is this a usual problem? When puting the new leather drivers seat in, it keeps getting stuck on the rail and not going anyfurther forward to enable me to click the pin through the front center runner of the seat. Tried for ages and have put the original 16v seat back in for now which just went straight back in.
I have looked at the rail of the leather seat and it doesn't look damaged so I can't see why it won't go in.
Anyone had this problem or got any suggestions? Really getting to me please help!!
  • Views 1.3k
Did you check the vehicle the seats were removed from?
Sounds like the runner or seat may be slightly bent out of line without any superficial damage showing due to accident damage in the car they were removed - this is a possibility but it could be something less trivial!
I'd suggest measuring the distances between the rails to confirm they are straight and true.
If the seat is slightly out, i'm sure it can be sorted easily enough - but don't take my post as gospel as without seeing it i'm stabbing in the dark!
Hi pololady, I had the same problem with my polo 6n2 drivers seat. But i worked out that by moving the seat belt HOLDER forward or backwards, will let the seat sit perfect on the runners. This will let you click the pin through the front center runner of seat. just try it worked for me.
Problem solved it's now in, took a bit of hammer and chisel, as think the rails on my car are a bit dodgy, but it's in, yay!!
