Lhd -> Rhd Converision
Right,
having bought my Genesis G40, my GF has taken a shine to it ("ooh , it's purple!") but would rather it not be a left hooker.
Other than a new dash pannel, pedal box & re-routing the cables..
What would be required to switch a left had drive mk3 over to right hand drive?
  • Views 1.2k
I think you'll lose the larger LHD brake servo and MC, this will need swopping out for the RHD version - I reccomend using the larger MC upgrade which is very cheap from GSF.
If the servo and MC is moving, i'd imagine the brake lines will need to be replaced too - but you should end up with a very nice new brake setup!
Hope that helps...
Dave
the bulkheads are different mate - it involves a hell of a lot!! reshell and respray is easier!
the bulkhead even has the wiper motor on the other side! the steering rack mounts are not there - u would need a steering rack.
its not like a mk2 golf where u just weld up holes and make others......DONT BOTHER! ul regret it if you do
KiZ
KiZ
as what kiZ said! way too much work as the cars are soooo different in terms of the bulkhead!
i have a L.H.D g40 i looked into this but the bulkheads are different it involves a hell of a lot of work!! reshell and respray is a hell of a lot easyer
