16v/gti Parts
I have the following and can deliver no problem. Pics will be supplied on genuine interest, when i say they're mint...they're mint :)
1.) Polo GTI Engine EXHAUST manifold-£50
2.) Polo 16v Ignition coilpack-£20
3.) A brand new set of H1 Osram Nightbreaker bulbs-over 80% brighter-£10
4.) Polo 16v airbag steering wheel-£10
5.) Polo 1.4 8v Gearbox (unknown code-will check) comes with starter too only done 70k-£50
6.) Polo 1.4 8v clocks-70-80k from R reg (later spec with SMT leds that backlight the dials and needles)-£20 (SOLD)
7.) Polo 1.4 8v plugs and leads-only did 100miles on them before engine was stripped-£15 (SOLD)
7.) Polo Headlamp protectors-brand new in box from vw-£20 (SOLD)
8.) Polo MK5 Headlamp switch-£10
I am flexible on price, postage not inc but i'm happy to get rid, so in some cases i will cover some of the postage.
Thanks kindly,
Sanj.
Edited by DubbPrince
  • Replies 20
  • Views 1k
You have a pm
hi intrested in the gti manifold does it come with injectors and do you no if they are biger cc flow rate the the standard afh also would the manifold bolt up to an afh head if you could drop me a pm thatl be great dan.
hi on the polo clocks would u do £20 posted? cheers steve
Dubway- sorry mate, i should have stated. Its an Exhaust manifold. I don't have a spare inlet to sell.
StevieDubs- no problem, i've pm'ed you.
what is the difference in a 16v wheel dude ?
will you accept £10 posted jus to get rid ?
cheers
Danny£10 posted is for free mate. not worth the trouble...no difference other than it came from a 16v.
speedo controled by rods or cable?
the speedo on all mk4 gearboxes is controlled electronically with a sensor on the gearbox...if you mean shifter mechanism, then it's rods...all mk4 boxes are rod change :)
BUMP- any interest??
Does the steering wheel differ from a 1.6 8v one?
The steering wheel is identical to any Airbag 6N steering wheel, leather with black stitch...
Reason i have it up is in case anyone requires a less worn wheel or a new airbag unit. 8-)
BUMP- still have these parts kicking about...take a look at the top of this thread. 8-)
i'll have the steering wheel off you mate, are you able to stick a picture up just for arguments sake :thumbsup:
cheers
i can do...soon as i dig it out dude.
Thanks kindly,
Sanj.
Interested in you are manifold mate how much u want for it posted cheers stu
hello bud, don't suppose you have any abs sensors for the front of a gti?
thanks.
You´ve got PM!
stu16v- £10 for post on the manifold dude...
are the bulbs brighter than normal headlight bulbs mate?
my ad above does state they are H1...polo's are H4 or H7. And yes...the osrams are upto 90% brighter and 10% whiter. :)
