Steering Wheels Help
am new to this vw game and a wantin to no, if there is any steering wheels off any other vw's will fit my mk3 coupe
thanks anth
  • Views 827
I dont know....but if it hasnt already then a g40 one seems to be the wheels of choice for quite a lot of people :)
Anything with a large spline should fit.
you can use several types of steering wheels,no matter if they are from a golf,passat etc.
the only hook:steering wheels wich has been built before ~1990? (i don´t know the exact date) will only fit with a small change.you have to remove a small hull from the steering rod.
I'm guessing you mean you have to remove the collar of the steering column to convert it back over to small spline?
right :D
