Service Checklist
Hi Guys,
Hopefully someone here can help... I was looking to find out where I could get hold of a service checklist for a 6n 16v polo. I am contemplating doing it myself so would like as much info as possible on what needs checking/changing/cleaning etc. Weekend job for meee...
Cheers,
J
  • Views 1.3k
inspection checklist?
wipers, lights, tyres, fluids
or service shcedule relating to mileage?
Edited by bobby_hill
I mean like everything that a garage would do if I put it in for a major service, a really extensive list basically. I know it needs doing now! I just want to keep the thing running for a little while longer before stripping it for bits because it's fubar'd.
air filter, oil filter, fuel filter and oil. Thats all i change for a basic service.
as sais above air,oil,fuel filter new oil may be plugs as well
as for a service check list you wouldnt be ablue to do half the stuff unless you have a ramp or some high axel stands be you cna check the wheel bearing abd ball joints and bushes just buy jacking the front wheels off the ground and holding the wheels and the top and rock it back and forth to check the bearings and then hold it on its side tand do the same to check the ball joints
genarally you will find a major service is that which includes a cam belt lol. whihc would be the above + cambelt...
an inspection is then carried out on an mot, think you have new car service/inspection confused with older cars lol..
if you mean an inspection best google "pre mot checks"
Cheers for the help guys, yes I have access to a ramp and any tools needed so that's not a problem. I'll try google. Thanks.
Also, if its not been done in a while, dizzy cap and rotor arm. I was amazed how much of a difference it made, and there was a thick buildup of carbon on the contacts inside the old dizzy cap when I took it off.
If you're talking major service, check the condition of the HT leads - if the silicon has really hardened up and they've been there a while, might be worth getting new ones, although they're a bit pricey.
For visual inspection, check the condition of your CV boots, inner and outer, check bushes on the wishbones to see if any are on the way out, look at your brake hoses to make sure they're intact, play in wheel bearings as previously said, check brake fluid level, thickness of brake pads, look through the inspection hole in the rear drums to see condition of brake shoes, adjust handbrake if needed, condition and tread of tyres, power steering fluid level, overall lookover round engine and 'box to make sure there aren't any leaks anywhere, the list goes on....
Essentially you can make it as short or as long as you like, depending on how thorough you wish to be. I think a mk4 haynes manual has the full list.
