Mk2 Polo Wheels Size
I've got a mk2 polo coupe s and wanted to know what size wheels fit ??
  • Replies 46
  • Views 27.3k
  • I've been running anything betwen 4,5-13 and 7-16, but I feel that 8-14 ET 20 was the best compromise betwen looks and drivabillity
Can you be more specific,before i write a list of thirty wheel sizes down? If you only need diameter for now,id say 13s and 14s.
Some have managed 15s with elastic band tyres.
Personally,i prefer the standard 5.5x13s over the 6x14s I'm currently using.
thanks what i wanted to know was whats the widest wheel i can fit to a standard mk2 polo coupe s
i would like some pics of cars on 15" please
pcd is 4 x 100
centre bore is 57.1mm
Ideal Offset run are ET20-35 (with a higher ET sitting closer to your suspension struts), VW wheels tend to be around the ET38 mark.
Biggest wheels on a mk2 comfortably would a 7 inch wide rim, probably a 14 at most. 15s can look good but even with the car lowered the wheels do tend to dwarf the small polo
thanks
i want a drivers car
whats best
Depends what you mean by a drivers car.
Mine was most fun on standard 5.5x13 et38 wheels with 185/60x13 tyres.
14" X between 5.5" and 8", depending on the offset. A low offset (on a wider wheel especially) means they will stick out the arches and are more likely to scrub on your arches damaging the tyres.
I am running 15"x6.5 and i regret it. I feel they are too big for the car.
Tempted to get these after Christmas
They are 14"x6 et38 pcd 4x100, will they fit ok in the arches at standard height? while were on the subject
Edited by Dollimore
thanks for that have you got a side view of your car ??
plus those wheels u want look very nice
grunge is right 15s do look a bit too big. That pic has made me change my plans i wanted to slam a mk2 on 15s but i think 13-14" are plenty big enough. 13x7 ats classics would be a good and common choice.
Looks even worse here
is that with stander shocks ??
and yes 15" do look a bit big on a polo
dame i wanted some 16" but i don't know wow
For the best drivability on a mk2 polo, in my opinion i would go for a set of Compo MO's, 14x6 with 195/45/14 Yoko A539s.
15s can look very good on mk2 polos, you just need to reduce the arch to type gap by some suitable lowering, 40mm is more than enough on 15 inch tyres but i would say 60/40 with a 60mm drop to the front, to give it a nice rake stance.
Try to ensure your front wheels arent going to catch on the arches, as your cars front wheel drive and catching the tyre of the arch mid corner whilst hitting a small bump in the road can lead to some brown trouser moments
dollimore, get some uprated shocks and springs on there and itll transform the look of your car, i dont think the wheels youve chosen are too bad, however for the age of the car and dark blue colour i dont think they go that well.
Id put my vote towards some castalletes and paint them white. 14x6 with a sensible et
i know someone that ran 15x7 g60s on a 70/70 lowering looked wicked
looks 10/10
practicality 0/10 lol they scrubbed when he turnt
yup standard shocks
With 14"x6 what would be a sensible et on the mk2, also what tyre size.
Thanks
looks 10/10
pretty sure g60 steels are 6 or 6.5 inch wide
id got for a 195/45 or 185/50 on a 14x6 rim. Id be looking at ET20/25 on an aftermarket set of wheels but on VW wheels like teardrops and such like your looking about ET35 ish
There's nothing worse than Escort cosworth wheels on a MK5 Cortina,and so many people just dont seem to get that a classic car needs classic style wheels. Any car needs wheels that suit its design,imt.
The FOCP :-p 'Grungeisdead' is probably right on 14in tyre size. I got it wrong though - my 185x55x14 Goodyears would be better suited to a daily 6n. And if anyone could re-do that selecta with black arch trims and 5-slot hocks for me to detail in paint,id be very grateful :unibrow:
These are the Castilettes with said tyres on btw,now summoned to the loft,possibly forever..
the cost of this picture... one set of castalettes =]
Ooh,I'm startin' to feel all christmassy.. ;)
are you
look
g60s are 6" and et 38 i think.
g60's were banded ^^^
its not your wheels that are too big. its your tyres
i love the way mk2 and 3s drive on 15s fitted with the right tyres
