Sump Guard
Evening...
As the 16v sump is annoyingly low, thinking of taking the plastic gaurd off to avoid ripping it off and getting the annoying road kisses...
Would this be a bad idea? I doubt the platic gaurd does much for big impacts, but how important is it that it stops splashes, and will the engine bay get filthy quickly?
  • Replies 15
  • Views 2k
shit sorry, please move mods!
mine got pulled off through a maccys drive thru lmao
the under tray is mainly to keep oil droppin on you are drive etc keepin water of engine i supose
i havnt got 1 anymore anyway....havnt had 1 for a while, semms to be no differenc in the bay gettin dirty tbh
I've still got my plastic sump guard, but then I'm only -40. I hit the MOT tester's jacks with it this year when he was driving onto the ramp, and the sump guard is covered in scratches, so it does take some punishment.
However it's not just the sump it protects, (but I suppose it does protect it from when you have to go through deep puddles), but there's also a lot of other stuff down at the bottom of the engine bay that's protected from debris, things like aircon pipes, power steering pipes, also is there a guard to stop stones getting lodged in the cambelt down at the bottom by the waterpump pulley? The way I see it - VW thought it was a good idea, so I'm leaving it there. And if I break it, I'll get another one.
Some good points in there mate. I think ill leave it on, and have a look at mounting it better instead of the crappy little self tapper type efforts!
And will someone please move this!
Edited by Tom66
Done, if you do it again, just hit the report button and explain.
I broke the little self tapping thingys that hold it on so I had to leave mine off. I haven't hit it or damaged it in anyway yet and I've gone through some scary deep puddles with it. Its not the lowest point of the car really, if the sump is on the deck the your exhaust and subframe will also be on or scrapping through the deck.
Does no-one make alloy gaurds for 6Ns? You get the odd 'idea' popping up on here but never heard of anyone selling them on websites etc. I think i just need to man up!
I've thought about making one out of a plate of metal, wouldn't be hard.
VW actually sell one but it is £70.
You sure? I payed £70 for a replacement plastic one!
What would you mount a metal one to securely?
was wondering if there was meant to be a cover under the engine. mine never had one when i got any one know how much they are to buy from vw?
OMP list two types of sump guard for polos, both 1.4 16v engines, i assume a mk4 and mk5 version (as these were the rally challenge cars). £152.95+VAT on demon tweeks
Hmm, cheers for that mate. I wonder if theyd reduce ground clearance anymore than plastic one..? I might give em a ring. Itd be interesting to see what they mount to aswell.
no they shouldnt reduce the ground clearance much more at all, remember these are off a rally car! they will mount to the chassis legs and subframe almost certainly.
when the xmas bonus comes ill certainly be looking at these...
Well the plastic one bolts to the chassis legs, so I can't see there being a problem with using the same mounting points.
Just got my car back from having gearbox/clutch done, and they've left it off, so I'm going to have to get the car back in the air over the weekend and get it back on. Those self-tappers are shit though, I'm always losing the damn things. Nut and bolt and some blue threadlock is called for, I think.
