Wots Lowest You Can Go
wots lowest you can go on a mk2 with standard steelies?
  • Replies 16
  • Views 2.3k
100mm... ish.
is this a mk2golf or a polo ?
sense would say that as he is on a polo forum that he is talking about the polo , however people do post up pics of their civics , puntos and other shite cars
LMAO :lol::lol::lol:
I seem to remember that one of the German tuners offered a 120/85 kit back in the days
There was a 120mm suspension kit for a Mk3 Polo on ebay before.. not sure on how genuine it was..
The car may roll 120mm down,but not on the roads you use. There's no good going 100mm down,then beaching on your first drive into work.
exactly you can lower it as much as you like but with standard of british roads as they are you'll just run into trouble. You'll lower it and your usual everyday run will be fine, and then one day on the way back from work you'll say to yourself "i haven't been down this way in ages" take a detour and forget that the surface is shit and loose a load of the waxouyl off your car.
stupidly low is ok for magazines but realistically its better off just leaving it a bit higher
id say play it safe with an 80/60 kit, that'll look nice and low and should be drivable depending on the condition of the roads that you drive on-failing that, 60/40 ?
tis a mk2 polo and it is my daily hack so need it to be useable
i took my brother and his 2 mates to the pub t'other week and it scrubbed when going round corners
dont want any fancy wheels as its a ratty shitter,just want it lower as am gettin a nose bleed from beein so high!
*whispers* the springs are gettin chopped!
the numbers you quote,which is front and back?
bump
the first number they say is nomally the front so eg 60/40 kit would mean 60mm on the front and 40mm on the rear.
Hi, mine with steelies on 135's all the handling you could ever need OHNEST NOT!DSCF0095.jpg
^Theres something about this car I really like. Obviously the twin carbs being one of them. You can't beat those steels, classic. Would like to see more pictures..
I've got a philj 60/40 kit with the rear at highest setting and feel some lowering caps on the front would get the nose down like above.
However I wouldn't want to go lower than that because of speed bumps and generally shit roads. I was in Edinburgh at Christmas time, what a nightmare ragged my exhaust like ten times. Some adjustment of exhaust clamps and height or something custom would definitely help.
Respect to folk who go lower.
Edited by MacColl
lower profile tyres?
wots the drop?
Hi, standard german Winter Tyres for 135/55-13 as for drop don't know as I got off a M8 but i have no problems(but you must change anty roll bar as it hits gear box end plate on the 5 speed box) lots and lots and lots of speed bumps on camp and no problem. but it helps German roads ar ALMOST smoooth...think it may be 80/60 drop
