Replacing Rear Windscreen Wipers
Hi,
I've managed to break my rear wind screen wiper! Any tips on how to replace one? I've got a 1998 1.0 polo. Have bought the new blade but it won't fit on and not got a clue how to do it!
Thanks.
  • Views 689
the plastic trim on the boot is held on by a single srcew inside of the recess hand grip thing. remove the screw and the plastic panel will just pull off then (the rest of it is held in by clips not any screws or anything).
You can see the lock mech and the wiper mech- pretty easy to get to and work on, depending how bad you broke it you may be best just going to a scrappy and getting a replacement or it all.
Post a pic of the damage if you like. if it just the arm, then it should be removable from the outside.
