No Heat Polo Brrrrrrrrr
Hi can anyone advise please I have a 1994 polo coupe 1.3, I have replaced the thermostat twice and still get no heat. the top and bottom hoses heat up the fan comes on at the right time and the temp gauge reads normal. hoses to heater matrix are warmish but not hot any clues please its bloody cold here in scotland :-(
  • Views 1.2k
you mean no heat in for the fan? or on the gauges in the clock?
Fan:
Possible airlock in the heater matrix. there should be a breather tap on top, with car running, slow open that and see if any air comes out.
only other thing i would say is, the dash vents will only blow cold, so close them off!
So many people ask that question!
Clocks:
faulty sensor!
faulty heater matrix?
mk3 heaters are shit as they only come out of the top vents not the main adjustable ones
Hi everyone thanks for you replies.....it was the heater matrix that was choked up so replaced it with another and at last its like the bahamas now thanks again, rel=ally appreciate the help ta cheeers
Is this true? Warm air only comes out of the upper non adjustable vents on my girlfriends car how can i make warm air come out of the adjustable ones? Just by replacing the heater matrix?
you can't!
the adjustable vents only do cold air!
