Breaking Mk4 1.4 16v
Breaking 1.4 16v Mk4 done 118k
Cylinder head, both cams,4 valves need replacing, AFH code £80, will split cover/cams/body if needed
Inlet Manifold £20
Outlet Manifold, £15
16v Dizzy £20
16v Waterpump £10
Alternator £10
Starter £10
Power Steering Rack/Pump/Fluid Res/Hoses £50
16v Injectors £10
16v ECU, Interior and engine bay loom, Fuse Box, Transponder Box/Ring, Key Chip and Coil Pack £45
16v Clocks, 118K, small crack in clear plastic cover but doesnt stand out when fitted £15
16v Dash And Doorcards £50
Radiator And Fan £15
1.4 8v Engine From A Mk4 96K, £90, Will Split If Needed
pics upon request
cheers, Jim
Edited by J1M MK4
  • Replies 41
  • Views 2.4k
hi mate, do you have both the front headlights and where abouts are you?
depending on where you are, a black carpet?
howdy dude, I'm after the full exhaust system, most importantly the cat pipe...
what colour is it? how much do you want for the drivers side door with everything in it? and whereabouts are you?
Have you got the door locking pins? If so, how much?
have you still got the bumpers and any pictures of them?
how much for rear parcel shelf and gear knob +gater, also interested in the black plastic surround for the radio/dials.
Alright bud, do you still have the gearbox? If you do, what mileage has it done and where abouts are you, my so called rebuilt gearbox just shat itself on the motorway so desperatly need another, cheers
http://dub-london.com/forum/viewtopic.php?p=9738#9738
PM'd
motty, only got drivers side, I'm in glenrothes fife
poloon, carpets gray
dknight, think the downpipes been stolen along with my 8v one too....
matty c, the doors blue
no locking pins, bumpers prov sold
no parcel shelf
5er for gearknb and gaiter
still got gearbox, 118k, I'm in glenrothes fife,
cheers, jim
Edited by J1M MK4
thanks anyway
What colour is it?
Need grill surround
no grill surround, soz
16v front hubs and everything needed for 16v frontbrake set up? how much posted :D
Cylinder head, all valves and both cams AFH code £120
Gearbox from same car, works fine, £120
Inlet Manifold £30
Outlet Manifold, £25
16v Waterpump £10
Alternator £15
Starter £15
Power Steering Rack/Pump/Fluid Res/All Hoses £60
Injectors £20
ECU, Full Loom And Fuse Box, Transponder Box/Ring, Key Chip(all electrics needed for conversion) £60
16v Black Dash And Doorcards £60
Clear Front Indicators £10
16v Rear Lights, small scuff from orbital sander on drivers side, not noticable £35
1.4 8v Engine From A Mk4 96K, £100, Will Split If Needed
1.4 8v ECU, Transponder Box/Ring, Keychip, Engine And Engine Bay Loom £20
splitting whole car so need anything just ask
pics upon request
cheers, Jim
what year it this off and whats the ecu codes
w/b ryan
so front hubs, discs and carriers, £40 but i dont know what its going to cost to post, best bet would be to arrange a courier yourself if you want
cheers,jim
what type of blue is it?
Hi Mate,
I need the glovebox under the steering wheel and the cigarette lighter and wiring,
Whereabouts are you based?
Cheers,
Jake.
its been sprayed so if your after a matching panel i dont have anything of any use
or8 mate you remeberd to get the codes today
w/b
rye
Hi
have you still got the HT leads and the cover that goes over the HT leads?
If so how much?
Ben
Pm'd
boomp
