Advice Before I Waste More Cash!
Hey,
basically I'm rollin a 5dr 1.4L 6n at the minute. No major mods just 57i and a piper catback system.
Experiencing some serious steering problems, hard to explain but I'm feeling like i should use the fault as an excuse to buy a better 6n to work with. Ideally i'd like to use the cat back system again as I've only had it for 2 months and it cost me a bollock! but would like a model with more mod cons if you will, and I'm starting to feel as practical as a 5dr may be it doesnt look as nice as the 3door.
Please anyone with genuine advice or an opinion get in touch
chars!
Edited by polocks
  • Views 1.5k
If your going from one 6N to another then why not just put your standard exhaust back on the car and then put the one you've had made on the new one? As far as I know the exhaust for a 3 door and a 5 door should be the same?
they should be the same if anything the 5 door exhaust will be a little bit longer
why would the 5 door exhaust be longer? :?
since when did exhausts have doors?
boredom ftw!!!
possible longer wheelbase to accomidate the 2 extra doors @ chrisbin
yeh its the same chassis, so no. the front door of a 5 door is shorter, hence i sit behind the pillar :mad:
