Rust Under Rear Arches
I've just noticed i have a small amount of rust under the rear arches, my dad says we'l have to wait till next summer to seal it, is there anything i can do now to prevent it spreading?
cheers
  • Views 1.5k
just try and keep the road salt out, by keeping it as clean as poss really...
I've also stuck some waxoyl on mine to see me through the winter... keeps the wet out...
ignore your dad, do it now, get yourself some sandpaper/wet n dry, a wire brush some kurust, some hammerite and a heat gun.
use wire brush to break off any loose rust, then use the grades of wet an dry to clean it up an smooth it off, wipe clean, apply kurust, dry with heatgun - carefully, apply another layer, dry, and a third if you fancy it. Paint with hammerite to seal, dry it off gently and put on another coupla layers.
then, come the summer you should have a nice rust-free easy painting surface.
did it on my rear arches, salt will eat unprotected ones over the winter.
Edited by Jackblack
I cleaned out every inch of my rear arches and then gave it a coat of underseal.
If its just paint that flaked off and its not to rusty I would just leave it until next year. It may get worst but it shouldn't get to the point where you'll need to cut the rust out and weld bits in. If you do a botch job now it'll make doing the proper job harder next year.
I advise a simple,half hour course of:
Warm up area to dry out moisture,but dont get it too hot.
Wire brush all the loose rust/paint/underseal off.
Agitate some instant Kurust into all rust with a brush (leave to dry naturally - it can dry before the chemical reaction is complete anyway). Leave for 20mins. Warm it all up again to dispel any moisture from the cold air,not too hot to touch,and coat thoroughly with Hammerite/Smoothrite.
Dont forget to go back and do the job properly when weather permits.
i'v found that kurust wont dry when its REALLY cold, like it's been past few days... hence gentle heatgun, done it on 2x squarebacks now, and no rot!
but yeah, kurust is the daddy!
where do you get yours mikey?
