The Rear Badge
Ok so I know there's threads about removing the rear badge of a polo 6N but how do you go about sticking it back on. Is there a certain glue etc. ??
  • Views 1.3k
Hairdryer it for 5 mins, an get an old credit card/bodyfiller applicator, slip it under the rubber outer seal pull it accross in a sawing motion.
Get down Halfrauds for some number plate adhesive in 1mm think, cut out a circle shape in the adhesive pads and bang it back on.
Cheers for that!!
Might just have to spray the badge something different.
  • 11 months later...
Cheers for the advice on sticking the vw rear badge back on, very helpful :-)
What about the 'POLO' badge on the back tho?
I'm looking to remove that, spray it black, and stick it back on.....what should i stick it back on with, because it isn't exactly a simple shape like the vw badge??? :?
just cut out little strips for the straight bits on the writing
Okay cheers :-D
Just a thought.....if i decided against removing the rear polo badge and vw badge...but still wanted them black...could i not just put masking tape and newspaper all around the badge and area, the just sand, prime, spray laquer etc... without removing the badges????
Would avoid the hassle of removing them and then sticking them back on surely??
dont be pikey and just remove them and then line them back up and put them back on. if you start trying to spray them while on the car its gonna end up looking gash as however much you try youll end up with paint on the car!!
