L.e.ds Inside Car
hello just wondering what the best way to connect up some leds in the car, i want to put some under each footwell and one on the center console bit, the bit infront of the gear stick, where most poeple throw there money into
  • Views 1.2k
anyone???
Get some that plug into the cig lighter, then when you get bored of them you can just unplug them and get rid lol.
Best way would be to just wire them into your headlight switch and then find an earthing point, it's not a hard job and they aint gonna take up much power.
www.barryboys.co.uk
try wiring them into the interior light also, then they come on when the doors are opened :D
You could take a feed from the cig lighter and put a switch in somewhere.
Look on ebay for neons designed for computer cases, usually work out cheaper than ones for cars. just cut the plugs off.
We currently have stocks of 6LED festoons which are normally used for registration plates or interior lights. As said above wire them to your interior lights so they come on when door opens and go off when shut.
£12.99 for a pair
Edited by Little Man
