Jl Audio E1400d Amp
JL Audio e1400d monoblock amp, used for a couple of months, no longer needed. Basically new, not a mark on it. In its box.
JL spec can be found here : http://mobile.jlaudio.com/pdfs/eSeries%...e1400D.pdf
£150. In Market Harborough
Edited by polopaul
  • Views 223
Link doesn't work mate. Is this the amp that you were using to run the 13w6?
Yeh ran it for a bit off it.
Spec:
# High-Damping Class D Circuit with discrete contorl circuitry
# Pass-through RCA outputs
# On-board crossover: Variable Low-Pass Filter: 20 -200Hz, Selectable Slope
# High level inputs
# CEA-2006 Compliant
# RMS Power Rating (14.4V):
* 4 ohms: 320 watts x 1 chan.
* 2 ohms: 500 watts x 1 chan.
# RMS Power Rating (12.5V):
* 4 ohms: 200 watts x 1 chan.
* 2 ohms: 400 watts x 1 chan.
# Frequency Response: 10 - 250Hz
# Damping Factor: >500 @ 4 Ohms / 50Hz, <250 at 2 Ohms/50Hz
# Input Range: 200mV - 8V RMS
# Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
# Dimensions: 11.81" L x 9.25" W x 2.36"H
