Battery Change And Alarim
Hi All
Thanks in advance.
I have Polo 1.4 cl(1998).
One week ago, I tried to start engine but it didn't work.
I visited a shop and she recommended battery charger.
As the electronic line is short, I took the battery out of the car.
First, I removed negative cable and then positve cable. Until then there was no problem.
When I lifted battery, the alarm system operated but it turned off after several seconds.
I didn't notice alarm system because I didn't use this remote control.
After charging battery, I tried to install the battery.
Firts I connected positive cable and then tried to connect negative cable.
At that time, problem occured. When I connected negative cable, there was spark and alarm operated continuously.
I tried disconnect several fuses(warning lamp system, immobilizer and turn signals) at driver's seat side.
But alarm system didn't stop and my car don't start. I also tried to use remocon but it was useless.
Please help me.
Thanks again.
Hang
  • Views 789
do you use this alarm or even want it?
I don't want to use this alarm system.
Hang
