Waxoyl/underseal
Hi there,
I'm looking to redo the rust protection on my sills and wheel arches, is there any way of thinning waxoyl or underseal to get away from the rippled effect and acheive a smooth finish?
I thought maybe just adding some industrial thinner???
obviously it need painting afterwards so..... any one got any tips/advice?
cheers
  • Views 1.8k
Hi there,
cheers
Are you using an airosol can or waxoil applicator ? either way stand the tin in hot water for a good 15 mins to watm it up it will spray thinner. If your using the applicator kit then ad some thinners. You cant paint it afterwards .... well you can but the paint wont stick as its wax, and soft and designed to move and fill the hole if it gets hit by a stone etc.
what is originally coated onto the sills, as this has obviously been painted when the car was built?
basically, i'm looking to re-do the sill in whatever protector it comes with only with a smooth finish in place of the ripple effect.
That is a product called "stone chip" this can be applied smooth (is) and is designed to be painted over. I think you can get smooth and textured. Try your local paint shop supplies.
right, i'll check it. is it spray on or paint on? cheers.
spray again rattle can or bulk mif you have a compressor.
Yeah, the grey stone chip is the stuff you need if wanting to paint over afterwards. Done the front of my mk2 in this for the OE rippled effect. You use the air compressor applicator like for waxoyl, but can use thinners in the stone chip.
Use stone chip on your sills and just sand it down, thats what my old man used to do on beetles and old dubs.
