1987 Mk2 1.3 Loon Modified
Well i purchased this from ebay and I'm not happy with it and i have no love or passion for it so I'm selling it, its a 1987 1.3 Saloon in red it has had the following work carried out by its previous keeper Been well looked after time he had it, oil changed every 5K with semi synthetic oil, plenty of new parts been put on since he got it, radiator, full new rear brakes including cables drums etc, cv boots, front wheel bearings, bottom arms, clutch and cable, probably loads of other bits, basically when anything went wrong it got fixed properly with new parts, and has no major defects i know of. and has the following modifications
Keihin carbs off Kawasaki ZXR 400 on custom inlet manifold with custom alloy airbox and cone filter
Facet fuel pump and Filter King pressure regulator
Ported cylinder head
Newman 270 degree cam and new lifters
Fuel injection exhaust manifold and twin downpipe
Lightened flywheel
Full Powerflow custom single box exhaust with single DTM tailpipe
Eibach Pro Kit Springs
Boge Dampers
Full Front end Poly bush kit
Mk1 Golf Gti alloys with Yokohama A539 185/60/13 tyres
239mm vented ATE Power Discs with calipers off VW Passat
Scirocco Scala front seats
The car is MOT'd until 7/7/09 and tax until end of april 09, the car has recently had a new radiator and while i have owned it it has had new plugs, distributor cap, rotor arm, plugs, thermostst, temperature senders (both on the thermostat housing).
The car has a JVC cd player to be sold with the car and if it makes enough money i may throw in some VIBE speakers, the car drives nicely and is pleasantly nippy for a 1.3 and it handles rather well for its age it will rev off the clock with no problems due to the bike carb setup.
BAD BITS, well since i purchased the car the temperature guage has not worked i have changed the thermostat as the bottom of the rad was not getting warm and both temp senders on the thermostat housing the guage works if you short the wires out at the sender and i have changed the sender so it has baffled me i will keep looking into it however on my days off to keep me out of mischief, The car has an eratic tick over problem sometimes it will tick over fast and others it will tick over slow and stall however it still drives fine even when its doing this, i think the carbs may need cleaned and set up properly, however included in the sale i have a weber DMTL 32/34 carb and a inlet manifold including adaptor plate and top end gasket kit so you could change to this carb if you get hold of a air filter to fit. Also included is some red overbraid fuel pipe and necescary clips to either tidy up the existing carb setup or
Even with the tick over problem this car is reliable and has never let me down and i use it day to day traveling to and from work.
The interior is ok the seats could do with a clean up and as you can see from the pics it has a few bits of rust here and there, underneath is sound and appears to have been waxoyled on a regular basis.
Am looking for £500 or offers very close to that as the car owes me a considerable amount more, will swap for something similar or a Suzuki SJ410/413 with a few little mods on it will also be willing to add or accept cash either way if its what I'm after please pm me for a phone number if its easier for you to talk via phone than here.
Edited by Daveo1983
  • Replies 22
  • Views 1.8k
What you after instead? My brother's got an e34 520i SE that he'd probs do a deal with if you were interested. Its silver with black leather leather/deep dish borbets (I think) and taxed an mot. Have got some pics if you want and we're in Cumbria-Brampton
If you can pm me some details and pics of it i could be interested :)
No probs. I'll get some pics and details and pm you shortly
You have PM
want someting similar?,
hows about a mk3 saloon, modded up a bit, low, 13's funky seats, 1,3 spi Gt cam, other shizzle?
giz a text bud and ill send over pics
07832273038
jimm
Change of circumstances now looking for a quick sale make me a sensible offer basically :) around £450 ish as the car stands me at a fair bit above this.
Edited by Daveo1983
all pm's replied to. will accept £425 without the weber carb and manifold
may break if enough interest as a few people seem to only want the car for the engine or springs and braking setup lol
you still got the car?
if so where are you at in cumbria? in in natland near kendal,
will look tomorrow afternoon or 24th if thats convinient?
stu
stu
Hi sorry took me a while to reply been very busy in work, I'm a butcher so its been mad this time of year, i still have the car and I'm over near whitehaven, your welcome to come and view the car whenever really if I'm not at home you could always come to my work its not a problem.
drop me a pm if your interested and i will give you my phone number as its easier to get hold of me that way :)
thanks
Dave
Mate can i just ask how good this car would be as a daily? Do the mods make it temperamental / fuel thirsty??
Ashley
Ashley
I'm using it as a daily at the moment and its not given me any problems, like i mentioned the tick over issue needs sorting but i reckon pop the weber carb on and that will resolve that issue or alternatively strip and clean the bike carbs whichever you prefer, fuel use wise i cant compare as the car i had before was a 24v 2.9v6 cosworth the polo seems to do well for a tank of fuel and like i say has yet to let me down. sometimes on cold mornings i mean very cold such as really thick ice on the windscreen it takes a few turns of the key to fire up but thats due to not having a choke cable fitted.
Ok mate, would be very interested in looking at this. Do you know if its a GT (75 ps) conversion or the standard 1.3 (55ps)? Get back to me whenever buddy. I'm going away for a week on the 27th so will be back the 3rd. Will come and have it off you when i get back :-)
Ashley
Edited by -Ashley-
Ashley
its the standard 1.3 but i reckon with all the mods and bits on it it could be heading for around 80bhp if not more I'm not entirely sure on this tho...
in honesty i need to sell this ASAP so i can put a deposit down on another car i have my eye on but if its still here your more more than welcome to come over when your back home :)
Ok matey just dont go selling it for really low money if you can wait at all, i will come have this off you. But if someone wants to buy it thats cool too. I will cross my fingers while I'm away that it hasnt sold. Only jokin, all the best. Might talk soon
Ashley
I'm not going to sell for stupid money anyways, enjoy your break and maybe see you in the new year
Cool man, cheers. Have a good one
Ashley
sorry to mess you about but i am unable to get a lift to come and view your car,
would of been a great project tho,
ill see if you still have it next month, providing i can get alift :lol:
sorry again
stu
quite happily pop down to kendal n show you the car, not a problem for me really
provisionally sold :)
hi interested in car if u still have it willl you tek 450 for it and were in the uk r u gi me i tx bwt i as i have limited internet access 07516636428 jonny
still got it for now, text's /pm's sent to those who contacted me :)
happy new year everyone
