Drivers Seat
hi guys I'm new to this forum so i might be in the wrong bit but I've got a n reg 1.3 5door polo and i was just wondering if there is anyway of adjusting the height of the seats ?
thanks, mike
mk4 then there should be a lever on the inside (handbrake side) of the seat pull this up and stand up in the car and the seat should rise or sit in it and pull the lever and the seat will sink
ahh right cool ill try it tomoz thanks alot will
it didnt seem to work it just moves forward and backward :S
should be a lever on the side of the seat as your sitting in it? maybe not in all models but i figured it would be as i had it in both of mine and they were 1.0ltr and 1.4ltr so?
check closely but you cant miss it really if its there
nah there isnt on there :( its well annoyin cos I'm tall I'm having to drive like a bloody frog cos its too high !
does anyone know if i could get a lower subframe maybe ?
Swap them out for a set of 16 valve seats, they have height adjust.
Going off the idea you don't have one, i'm imagining you own an 8 valve.
They are an easy swap, basically just put them in the exact same way you take the 8 valve ones out.
