Eaton Toothed Pully Set Up ?
as title says does anyone know where i could get one from {if i can get one} i,ve seen a few people using this set up but cant find who sell them. was it only psd chargers that came with toothed set ups? or is their anyone whit a different eaton set up using toothed belts
any help on this would be great
steven
  • Replies 12
  • Views 1.2k
off the top of my head and from searching google i think it was only the psd eaton kits that came with the toothed pulleys :(
NOOOOOOOOOOOOOOOOO i need one
Seems only PSD did them. I've found some for when I get my eaton.
You'll have to get some made or modify some pulleys.
am i right in thinking i can use the crank and alternator pullys from the toothed psd kit so i would just need a supercharger pully making to fit the eaton charger???
steven
steven
:nod:
steven
:nod:
ahh good good right i just need someone who can make me a 19% smaller than standard toothed pully to fit the standard eaton charger
any takers ????
surely they must be a demand for this pully as their is more than just the psd eaton convertion out their so they must be a lot of people running the standard belt
psd kits run a 19 [maybe 17] reduced pulley
I could probably get this done for you but as it would be a one off it wouldn't be cheap £25hr labour +materials and overheads.
also check if your going to be needing a new belt, off the top of my head I cant remember how much the tensioner had left in it.
how many hours would it take though????
I couldn't tell you with out ripping an eaton apart :( as only then would i know what needs modifying, fabricating etc etc.
Ill have a look into though when i start on the eaton kit remakes this christamas :)
ok let me know
it should only be a case of getting a toothed pully made to fit the standard eaton that is 19% smaller that the standard sized pully, job done
steven
