Rooflining
does anyone know where i can get custom style headlining from?
I've seen people with beano comic style and things like that any ideas?
thanks in advance.
  • Replies 9
  • Views 1.5k
headlining? if its a mk4 then take the visorsmgrab handles off and then remove the pillars and down comes the headlining, trim in your chosen material then refit
mine is furry :)
mine is furry :)
cheers for that mate i wanna know where to get it from? any ideas?
what the fur? or the headlining
Just go to a local material shop.
The job gets a whole load harder to do if you have a sunroof however, but I managed it with a little force =]
I used black velor.
I also now have white leather pillars :-D
Edited by DubDanny
how did you do the sunroof bit danny??
I've got a sunroof but wanna retrim my headling black...have no idea where to start..i.e what to and how to remove bits before pulling it out
plus theres like a trim round the edge of the sunroof inside which would need doing
sean
The trims are solid dude, best thing I could suggest is spraying them, which is a brave job to do inside a car. To do that you'd have to strip everything you can out and then mask everything off.
As for the headlining, simply take out the sun visors and grab handles. You then will have to remove all of your pillar trims which include the front two, the side pillars which have your seat belts on and the whole back plastics such as the 2 pieces which hold the parcel shelf on, then the big plastic pillar molds above them, which lie above your first aid area and opposite.
Then basically pull the headlining down, it should fall from the back. The front is the tricky part. You have your sun roof winder along with your light. Just get a flat head screw driver under the interior light edge and prise it out, then push it up through the hole out of the way.
Then it's basically, pull evenly around the sun roof winder being careful not to tear or deform the headlining, and when it's all pulled out around, simply remove through the boot.
how have people gone about sticking the material to it? whats best to use just spray adhesive?
You can pick up some pretty cheap from a local DIY shop. I used one called Super Adhesive in a blue can with pink writing. Did the job spot on.
You will be better off with a spray can as the area you have to cover is pretty big.
Make sure it's heavy duty stuff as well...will usually come out slightly stringy if it is any decent.
just make sure its high temperatur adhesive as when it gets hot in the summer it will start to sag
