Mot, De-wipered & Lowering
will my car pass its MOT if its been de-wipered and does it need to be a certain height
  • Replies 12
  • Views 1.7k
if you mean rear window de-wipered thats ok.. a car doesnt require one. if it was broken then thats a different story. as for height it just needs 2 fit on the ramp/rollers.
hope this helps..
david.
Edited by riskie
as said above if you de-wipered the rear then it won't be a problem because alot of cars don't have one from the factory
also height just needs to get on ramp and the wheels not fouling the arches
Sorry to hijack the post but on the subject of MOT's
I was reading they can fail you for having a chip in the wind screen
I'm TFT so wind screen cover but the chip is only visible if u go looking for it
Do you think it will be failed for this?
it all depends on how big it is mate.
its not that big
you would only notice that if you went looking for it really
I have read that already lol
That why i am asking it is in section A as per the link provided , but i am unsure of whether it obstructs the driving view
De-wipering: If it's the rear, no problem.
Lowering: Depends where you go, he didn't take mine on the rollers, he just tested the brakes with an in-car tester.
Chip: It shouldn't get failed if it's not so noticeable that you find it with a quick glance over the windscreen.
My old car passed with a chip in the screen that was about 3-5mm round.
for chips in the windscreen it ok normaly as long as its not in the drivers view
alls you need ot do is look at the area of the screen that is as wide as your sterring wheel and if it aint in there your ok
Thats probably why mine passed then. If it was a LHD one then it wouldn't have :lol:
Thanks for the help guys
