Kreg Mk3 Polo Genesis Bits, Dirt Cheap!
Hello there this is the full list of what I have left :
Split Rear Bench Seats, good cond. no splits or tears just one barely noticable pulled thread £5 collected
Rear 'door cards' or interior panels, good cond, just need a clean £5 collected
Parcel shelf with 6x9 holes £4 Collected
ECU from 1.3spi £15 posted
front speaker covers from ontop of dash £2 each collected
Drive shaft boot joint rubber thing £2 collected
Drivers side and middle rear belts again, including the bit you clip into £2 each collected
Handbrake handle with plastic trims £4 collected
Radiator fairly good nick, no leaks and holds pressure. £5 collected
Washer bottle with pump still attatched £5 collected
Complete Airbox £5 collected
Pair Headlights very good condition, no scratches, including bulbs £10 the pair collected
Pair front indicators orange, not clear £7 pair collected
various bits of trim £1 each collected
door handles
window winders
bits that hold the rear seat from the top
sunroof winder
interior light
Other various bits £3 each collected
passenger side sun visor (with mirror)
rear view mirror
towing eye
header tank
trim from around steering column
Petrol Pump The one from near the driverside rear wheel £10 collected
Set of clocks has rev counter. milage reads 119733 good cond. £15 collected
dash speakers £5 pair collected
heater control panel £2 collected
original scissor Jack and winding arm £2 collected
12 wheel nuts and 8 short black caps £1 the lot collected
Bonnet (black) No rust but couple of small dents and scratches £5 collected
Doors (black) . Both still have glass in. Drivers side ok condition, no major dents or rust, just bit of chipped paint work where was rubbing on arch. Passenger side has small dent from idiot in carpark £5 each collected
Drivers side wing (black) good condition, £5 collected
Rear windows £4 each collected
Front seats good condition no rips or tears (pattern as on the rear seat above) £5 each collected
Lowering kit think this 40/60 not 100% sure, in really good nick as only on car for a month! Make is 'janspeed' £70 collected
Kenwood CD player brilliant stereo headunit, cd and aux input! RDS, traffic, removeable front etc barely a year old, still have receipt. £30 collected
Maplins 90 watt speakers fit nicely either side of parcel shelf on a mk3 coupe, again almost new £10 collected
As you can see all prices are as collected. if you want them posted (only smaller items) then PM me for a price.
alternatively you could text or call me on 07514777473 any time of the day
Am open to offers or bulk discounts if you want a list of things!
Edited by Starry
  • Replies 49
  • Views 2.4k
do you have the plastic cover that protects the painted area near lock and is it a coupe or squareback you are breaking
hi mate what wheels are on it? and what stering whee an interior ?
what condition are the bottom ball joints and track rod ends
"do you have the plastic cover that protects the painted area near lock and is it a coupe or squareback you are breaking"
sorry I'm not sure what you mean. but its a coupe.
"hi mate what wheels are on it? and what stering whee an interior?"
Its got standard wheels (13in), they're in ok nick but one of the tyres in bulged.
But I've also go 14in corrado steels and 15inch mk2 golf steels. i want to keep one of these sets but i dont mind either if you decide you'd like one of these.
The interior is the tartan style, in good condition except the headlining which is really grubby. The steering wheel is the 3 spoke standard one just like in this pic http://i125.photobucket.com/albums/p71/sta...305/poloint.jpg
"what condition are the bottom ball joints and track rod ends"
Not a hundred percent sure. the car had an accident with a curb and something has snapped (i was told the 'suspension hanger') but i havnt had a chance to look under the car yet. will check at the weekend and let you know.
Edited by Starry
hi mate what do you want for the stering wheel? and what 13s are they?
how much for the passenger rear belt delivered?
How much for the Sub-frame/rear axle? Cheers
In Jan I'd be interested in:
- In-line fuel pump
- Entire in-tank pump/level gauge assembly
- Fuel cap (& keys?)
- Both wing mirrors
- Silver front & rear badges
- Possibly dash speakers (if in ok 'nick).
- Boot struts (both ok, not lazy?)
- Heated rear window, fog light and headlight dash switches
- Indicator / wiper stearing wheel arm pod
- Passenger seat angle wheel (pretty pikey I know!)
- Boot mat
- ECU plastic cover (if in good 'nick)
- Rear wiper motor (can't rememember - think this includes the washer nozzle etc.?)
- Hub caps if they're the same as mine
I'm in Coventry so can pick up bits from you no problem.
How much for the lot?
- Chris
P.s. - might also take a look at the windscreen as mine is quite scratched by wipers
Edited by cheys03
How much for the Set of 13" original steelie wheels and the front seat and rear bench??
Hi there, can you tell me what colour the seats are? And are they in good condition?
Thanks, Adam
Starry, how much for the bits listed above, minus the fuel pumps?
Will be bringing a box of bits with me to Aldon on 24th so keep an eye out for me if you want anything.
anything in particular (small bits) message me and ill see what i can do
hopefully it will be ready to strip properly the weekend before Aldon!
Edited by Starry
whole front seat belt stuff?
are the door cards availbe still and if so how much posted cheers
Would you happen to have the plastic shelfs that sit either corner in the rear holding the speakers and supporting the parcel shelf? Those two bits posted to Woking and I'd be happy?
Does it have green tinted windows? If so, how much for the 2 rear side windows? Cheers
i certainly do, they're quite light if i recall so £15 posted?
I'm afraid it doesnt have green tinted windows, just plain glass ones.
Bump!
Have you got the lower radiator support bar?
Could come and collect as only in Coventry.
bump need stuff gone soon!
hiya m8 i need a cold start for my exhaust. and some rubbers off the two front doors
where in warwickshire are you cause i can collect on sunday
Dont have a cold start for the exhaust sorry but the doorrs are in Shilton Industrial Estate
Bulkington Rd, Shilton, Coventry CV7 9JS,
let me know when you'd wanna pop by so i can make sure someone with keys is there.
do you have cigarette lighter?
any nicks or rips on gear stick gaitor?
do you have the drivers door speaker cover?
am i correct that this will fit a 1997 polo 5 door?
How much to get it delivered to belfast?
hey, the gaitor is in perfect nick, no nicks or rips, the doors dont have speakers and it didnt have a cigarette lighter I'm afraid.
ill do the gaitor £4 posted.
cheers
