New Parts List
Hi all,
just posting on here to vent my frustration over my car, it's really winding me up now.
So far it's had:
On the front:
New wheel bearings
New wheel bearing carriers
New hubs
New calipers
New caliper carriers
New disks
New backing plates
New pads
New brake lines/hoses
New solid wishbone bushes
On the back:
New calipers
New disks
New backing plates
New pads
New handbrake cables
Problems I'm still having:
Hub nut on one side was replaced, need to do other side ASAP.
Handbrake cables need correct metal ties
Rear caliper carriers keep on coming loose, going to buy new bolts
Knocking noise still on the front, even after replacing troublesome voided bushes with solid ones.
Cause of the knock is the steering rack :(
I'm just fucking sick...
Anyone else having this sorta luck? or is it just me?
Oh and my brake light switch failed too! Plus the headlight adjuster light has failed and i've got an LED out in my high level brake light.
  • Replies 37
  • Views 3.5k
i think some cars are cursed
my GT when i got it, felt like i was forever replacing bits....every week sumat broke
thats a big list for a 2003 plate car!
I've hardly had to replace parts on mine, if any.
Ain't that a bitch!
my rear carriers came undone once, you are meant to loctite them in (VW specify it!)
were loctited!
Buying new bolts, sure they're only one use... as are hub nuts.
how can you have single use bolts? the only reason single use hub nuts exist is because they're ovalised at the end to cut their own thread, that doesnt happen with bolts.
which loctite did you use? there are different grades.
if I just buy the new bolts, they come coated already. Better safe than sorry...
I think its red loctite that's best for bolting up the carriers isn't it?
dunno the proper VAG stuff is green. i actually bought new bolts and they didnt have loctite already on them when i got them
stretch bolts are one use only, such as flywheel bolts, head bolts.....
Caliper carrier bolts usually have to be fucking seriously tight!
Wow Panda thats a hell of a lists for a car so young.
It's exactly the reason though why I will avoid buying a car newer than my valver for as long as possible. T reg valver bought it on 110K miles in february and I have done 25K miles in it so far and all I've had to replace is a tyre!
my theory according to the psycology of polo's is that your car is suffering from 'spoilt brat' syndrome where as you have always brought it nice bits and spoilt it its got used to it and so wants more and more attention.
I still maintain that the cars that have had the tougest start in life and ended up being on the verge of being scrapped are more grateful and go wrong far less that cars that have always been well looked after and spoilt.
both of mine were saved from the crusher and over the last 8 years i really can't think of many things that have actually gone wrong or broken aside just general maintenance or me upgrading things because i want to.
the minute they start being all cocky and trying to act like the boss you need to put them in their place and take it to the scrappy and point at the big grappy thing, let it watch a few cars being squished that'll teach it :lol:
remember polo's are pack animals, need to show them whose boss :-D
As mentioned above make sure you have the right loctite. I have 3 different types sat here in my drawer at work. Loctite 270 is the green one. I wouldnt trust bolts that already have it on them already.
Edited by tomadomeit
^ LOL.
Seems kind of true. My red square was destined to go to the scrappy but I picked it up quicker than the scrapyard people so I got it. Never gave me bother that car.
Smile man it could be worse
if they're high stress bolts, which carrier bolts are, they can stretch when tightened back up.
like head bolts. if you use them again theres a very big chance they can snap when tightening!
but they aren't stretch bolts, they're 12.9 socket caps.
hello stranger!
Long time no see Sarah. :)
Blah thats not bad luck, you want to spend a day in the life of Craig :lol: you`ll leave dreaming things can only be as bad as what youre getting :-p
and tonight, engine managment light came on.... great.
coolant temp sensor faulty now :(
jesus
thats mad
do you thrash it everywhere?
nope.... and it gets serviced before the intervals with genuine VW parts and oil.
my point has been well and truly proved, I rest my case! :lol:
don't clean it or pay it any attention for a couple of weeks, teach the cheeky bugger a lesson :nod:
