How Do I Remove And Re-fit Rear Skirt On 6n
Hey peeps
Can someone let me know how to get to or how to remove the rear skirt, i have a new one re-sprayed and wanna get it put on before the even worse weather comes!
HELP!!
  • Views 951
Is it an 8v or a 16v?
I'd assume that by you saying rear skirt, you mean the rear valance on an 8v.
If I recall correctly it's just bolted on to the rear bumper (the top half of the bumper), so get under there with a spanner.
if it is the lower 8v valance, then open the boot remove the 4 bolts you see which are concealed by the boot lid, then remove the screws in the arches (you may need to remove the wheels) then the top half will come off - not very easily though it will feel like there are more bolts to remove but you just have to give it a serious tug and it will come off, then youll see all the bolts to remove the valance. there are two bolts underneath the bumper on either end get em all off, put the new one on and reverse the whole process!
thanks alot for your help guys! lets see where that gets us!
I just hope the bolts aren't rusted on!!
x
