Www.g-laderseite.de
i've been looking at the products for the polo
hers some links to the items i've been looking at
http://www.g-laderseite.de/eshop/product_i...products_id=118
http://www.g-laderseite.de/eshop/product_i...products_id=110
http://www.g-laderseite.de/eshop/product_i...products_id=107
http://www.g-laderseite.de/eshop/product_i...;products_id=58
i wanted to know who's using them and what you think about them
Edited by mark_crox
  • Replies 26
  • Views 3.2k
i have everything you posted on my car and they are all great. :D
have you
what suspension have you got ??
i'm going to be running the philj 80/60 kit
Edited by BSJ1
i have all od these parts but haven't fited all of them i have had the rearor beam bushes in for about 2months now with no problems
used to run powerflex wishbone bushes lasted about 6months not that good i think these seam better
thanks
i'm using home made coilovers with bilstein dampers
did you find the G-lanerseite bushes made a difference
and how good are the lower arms ?
green blocks rule.
the green blocks are a very good starter mod, as are the outer poly TCA bushes
wall i've order that lot 2day
let me know what the tca arms with rose joints are like. fancy a set myself.
they're alright, for lots of mileage you would need to keep a close eye on the inner joints as they haven't got any boots to protect them from water/grit/salt etc
could you just apply some heavy duty graphite grease or something?
:lol:
this is the issue with running race spec bearings, you have to basically WD40 them every time it gets wet/washed.
:lol:
sound fun :-D
if i'm doing that i'll end up putting the car up on ramps and cleaning/polishing the under neath of the car
Same here. Don't think i need any yet but cant be any harm in replacing them anyway!
yer i will do
when i get them i'll start a project page up
Edited by BSJ1
:lol:
fuck that.
long-life grease 'll be reet.
check em every other wash, should be ok provided you dont jet wash the poor buggers.
i got my G-lader goodies today :-)
i will get some pics up when i fit them
I have solid alloy front mounts,same design as G-laderseite. They hold stabiliser bar 16mm further forward,to compensate for the front being 55mm down. 3-bolt fixing instead of 2-bolt. Made them myself.
But combined with the engine torque,they're not kind on TCA's.
what TCA's are you useing ??
i've got the G-lader ones
  • 2 years later...
Hi guys are these top mounts worth the extra cash over the OE ones and do they last longer. Thanks Chris
free bag of haribo with every order and the top mounts should be pretty good.
oh and holy thread revival
I cracked four topmounts within 3 rallies. not the actual top mount but the rose joint bearing which sits inside it. but that was under harsh conditions. I ended up going back to standard top mounts.
I know this is way old, but how did you get -55mm down mikey?
