Www.g-laderseite.de
Had 40mm front springs and took off 1.5 'helper' coils (the ones at the bottom that touch eachother and do very little else but help ride quality on poor roads).
Id turned the damper pistons down 10mm on a lathe to make the springs reach the stroke,and made that work with a custom fitting at the top mount (spacer for the castle nut), with the Punto top caps i still use - so i had soft suspension 55mm down.
Only binned it for a hard 60/40 kit i soon sold on. Shouldn't have binned the soft 55/40 kit.
  • Replies 26
  • Views 3.2k
hmm, the top mounts - would they be ok for road use? the roads near me in devon/somerset are very bad.
I went to VW and OEM top mounts are £33 each. GSF ones are probably a lot less but not sure what to go with.
Sus kit will be the AP 40/30.
