Fitting 3point Harnesses
i have a set of Schroth 3 point harnesses, i cant seem to find anywhere to bolt the 3rd point down? i want to keep the rear seats useable. any ideas where i can bolt them down? dont really want to drill anywhere.
  • Views 921
the long and short answer is, you can't have harnesses and use the rear seats legally.
damn ok ill have to see what i can do but i think the answers going to be leave them for now. i may fit them and have them so i can use them for shows and stuff
Unfortunately theres no compromise with harnesses and keeping rear seats.
Initially I ran 1 4 point harness upront, which left be with the passenger side rear still useable, and ofcourse the passenger front seat.
As soon as I got a pair of 3 point harnesses upfront, there wasn't a chance of keeping the rear seats useable, as you either end up using the mounting points for the lap belt and the seatbelt buckles, or you end up using the C-pillar mounts for the belts themselves (which I wouldn't advise, as in a major rear end shunt the C-pillars could be pushed inwards, meaning all tension from the harnesses is lost and you go face through the windscreen).
