Which Is Quicker...
Just dont spend to much on the 8v, you will need the 16v in your life soon enough! :lol:
  • Replies 116
  • Views 8.8k
I'm looking into a mk2 golf gti. not to bothered about mpg but more reliabilty, speed and handling. what do i go for gti 8v or gti 16v
16v!!!!!
alright alright, i want a Digifant so i can drop a VR6 in it next year....
The amount of times i have been asked a meets "Is your GTi a 8v or 16v?" I wouldnt want to imagine the look i would get if i said it was an 8v :lol:
why 16v compared to 8v then? and how expensive and easy to tune are they?
To help the 8v digi lag, do the spring tension modification on the AFM:
"Later Digifant cars appear to be tuned to run lean from the factory.
One tweak which is known to L-Jetronic tuners and that can work on the Digifant cars is to slightly loosen the spring tension on the air flow sensor.
By reducing the spring tension on the AFS you are essentially allowing more air to flow into the intake for a given throttle position. This "tricks" the computer into supplying more fuel at lower RPM, in effect richening the mixture throughout the range up to about 4,000 RPM when the AFS is wide open anyway.
Reducing AFS Spring Tension
To reduce the spring tension, first remove the black plastic cover on the air flow sensor by cutting up through the silicone sealer with a sharp blade. You will see, among other things, a black gear-wheel on top of what looks like a clock spring. A wire clip engages a tooth on the gear-wheel and is held in place by a 7 mm screw.
Scribe a permanent mark on the gear-wheel at the tooth where the wire clip engages (This is so you can go back to the stock setting if need be).
This is the tricky bit: Get a good grip on the gear wheel with your fingers. Loosen the 7 mm screw and wire clip assembly. Don't drop anything, and whatever you do, don't let go of that spring, or you may never get the car to run correctly again!
Now, carefully unwind the gear-wheel 3 teeth counter-clockwise. This is no more than 8 or 9 mm, so be careful. Reset the wire clip three teeth to the loose side of stock. Tighten down the 7 mm screw, replace the black cover with a thin bead of silicone sealer and you're done.
I tried one, three, and five teeth... one didn't seem to do much, five actually reduced power. Three was just right. Stay with three teeth because the down side of too rich a mixture will be increased emissions, and possible damage to the O2 sensor and/or catalytic converter. YMMV.
I can report that this tweak helps solves some perceived Digifant driveability problems (assuming all else is in order). Hesitation is reduced, throttle response is crisper, and there is mildly quicker acceleration in the lower gears due to increased torque. Gas mileage does not appear to suffer much"
Found on ClubGTI a while ago!
16v has 20-25 bhp more, but the power is at the top of the rev range, 8vs feel more torquey but have less bhp
Atleast you used the word "8vs feel more torquey"
1.8 16v
139 bhp
168 Nm / 124 lb/ft
1.8 8v
112 bhp
153 Nm / 113 lb/ft
The graph below is the factory figures for both engines is standard trim. (no point comparing anything else)
So the myth about torgue is just that, A MYTH!
Power and Torque is always higher on a 16v.
not on a mk4 polo its not :Pso for a good gti 16v how much am i looking to pay? and how easily tuned are they and cost?
Good GTi's vary alot on prices depending on where they are advertised. Places like Edition38 have very over inflated prices. I reckon the best place is Pistonheads, or even Mk2 Golf Owners Club.
I suppose the local Trade-it is a reasonable to find one.
Price wise, £1000-£1500 gets a pretty good one and prices go over £2000 for some cars.
Turning wise, its easy enough to use a 9A 2 litre bottom end, good exhaust and air filter and you have potencialy 170bhp.
cool so not to expensive to tune then i might look into insurance for next july when I'm 19 with 2 years no claims and hopefullt advanced driving cert done to. will i be lucky to get it under a grand with all that?
The 2.0L conversion can be done for £500-£600 as you will want to replace things whilst your doing it.
As for insurance i insured my golf a couple of months ago for £850 TPFT - 20, 3NCB, 3pts for speeding.
that pretty good so hopefull it wil be around that mark. is that the 2.0l bottom end or whole engine? if theres a buyers guide or a good old detailed list of what can go wrong and what to look for would be great :D
Just looking through cheers mate. do they have power steering? whats the best model to go for in the 16v range or is there only the one
Most desireable is the 90's spec (Has whats called big bumpers among other things).
Alot of the late 16vs have PAS (Mine does) and come with c/l and e/w. Mine even has an electric sunroof and leather interior. There are allsorts of other extras in some of them - electric mirrors, Air Con......
I would look at a few before making a decision, the main points to judge them on are bodywork and engine, not the amount of scene points you can get with the extras :lol:
i dont care abot scene points :lol: theres quite alot that can go wrong isnt there :lol: would a mk3 golf vr6 leather interior fit in a mk2?
More extras is more stuff to break! Most (if not all?) 16v have central locking and electric windows...Nothing on them is really a big problem to fix - i'd be more inclined to get one with good bodywork as you can pick engins up for under £200.
So a 1990 mdel onwards is best to go for then
Depends if you like skinny bumpers or big bumpers, your the one driving it! haha
with 16v yeah, it depends on the skinny or big bumpers... There was different interior patterns available in 90/early spec aswell. If you buy 8v you have to decide on k-jet vs digifant and all the 16v points.
erm il go for 16v I've seen small bumpers but not big ones so dont knowwhat they look like :lol: would vr6 interior fit stright in? 16v is digifant right? heard thats the better one
Big Bumpers:
Not sure on the VR6 interior tbh.
16v's (All of them!) are K-Jet.
I got a 8v just because it was solid as fook and damm tidy. I wouldnt be inclined to a 16v just for the engine, yes they are fantastic cars but only if they are solid. Find a buyers guide and take a torch with you, bear in mind some are now 20 years old. But find a minter and your sorted :)
Sam
