Scraping And Need Orange?
Hello there well I've managed to put the alloy wheels on my car due to the change in insurance.
First problem is that its rubbin in full lock on the mudflaps and the bit of plastic above the mudflaps as well just a bit tho.
I was wondering what the solutions are, taking the mudflap off would help but then the plastic is still rubbin above? Cheers
O does anyone know where i can get some orange hammerite from? for the drums? Cheers
ill try and post some pics of the pistachio beast tomoz :) thx
  • Replies 13
  • Views 1.9k
Just trim away the bits it is rubbing on, or if it is just rubbing on the plastic a little - wait until it wears down enough not to rub any more...
Mine rubbed on the arch liners a bit (I assume thats what you mean) and I just let it rub through. Didn't damage the tyre at all and it doesn't rub anymore.
try mixing red and yellow?
is hammerite what i should b using on the drums? and yer ill give tht ago as long as its not to expensive lol :)
orange drums = fail
mudflaps = fail
imo... and my opinion means jog all :biggrin:
I like your car though... the orange nose looks good
Hammerite is about a fiver a tin.
orange drums = fail
mudflaps = fail
theres just one problem lol i dnt want to do the same as everyone else has done and therefore operation tic tac will be in order ill try and get some pics up of it so far in tomoz as its not light enuf again now lol :(
do they do yellow hammerite?
i sprayed one set of drums on an old polo with normal car spray. Left an old set of bolts in so that the spray didnt clog the threads. a couple of coats and all was good. probably be cheaper than hammerite ?
like Kam said hammerite isn't expensive...
I've seen cheap tins of paint for brakes, engines and other hot stuff on ebay in all sorts of colours... no idea what it's like though
Yeah you can get yellow hammerite.
orange caliper paint maybe (halfords) :D
cheers ever1 ill go dwn halfords wen i next get paid altho I've just spent 220 on new tyres for the wheels needed lower profiles now on 195/45/14s so expensive and I'm doin this with no coilovers on so its guna look stupid with that arch gap for a cople of weeks lol :)
mate of mine painted his 6n drum`s in day glow orange ,said he got it off the net , was well bright . you may as well try and keep you flaps if you gonna go low its gonna rub anyway (till its worn what ever away) and the worst that could happen is they fall off lol
