Mk2 Lock Set
i think i need a whole new lock set as my boot lock wont turn, so where can i get the lock set from?
and how hard is it to change the whole lot?
  • Views 1.2k
spray the lock with wd40, its probably just siezed up. there is a guide somewhere on a more permenant fix, not sure if its on here or on uk-performance polos site.
if it was siezed would the key still go in?
i took it off today but there seems no way to take the lock out off the handle.
anybody???
Mine stopped working,there felt very little resistance when i put the key in/out so i figured the pins were stuck open from gammy,dirty old grease.
I sprayed some WD40 in there and it didnt do much. So i took the lock out,and sprayed like a whole can of WD40 in there,shaking the lock plenty,and that washed it out. And it worked.
This was a couple of years ago,and its not given me a problem since.
ok thanks its not hard to get out i had it out the other day, but i couldnt find a way of getting the lock out of the handle but i will give that a try cheers.
