Mk2 Coupe Bumper Removal Give Me A Clue
hi all got a mk2 coupe s want to take the bumpers off for getting them black again. any help or advice cheers
  • Views 1.3k
yes, its 2 bolts per bumper, what more do you want to know. requires a ratchet and extension bar, thats all.
you can heat gun the bumpers to a natural black, rather than the super shiny fake finish you get from back to black.
But paint is better. Vinyl paint or bumper paint straight to the plastic are best. I've not found a plastic primer that sticks well,so my advice is to avoid that somewhat obvious method.
if you are going to use plastic primer its best to use 1k and make sure the surface is as clean as you can humanly get, put on 2 dry coats and let them dry( this will give the rest something to stick to) then bash on 2 heavy coats, when thats dry you nee to put on normal primer again 1 dry coat and then 1 heavy and nib this back with a grey scotch pad. then you paint them what ever colour you want!!!
but just to get the origonal bumper look back i would use the heat gun method just dont go to mad, just till you see a change and always keep it moving!!
on plastics like this it is vital to use a decent adesion aid/promoter.
this is a clear spray which etches up the plastic so you dont have to
damage the texture scotching it up.
Cillit bang then vinyl dye. Job done.
