Someone Who Knows About Bodywork?
I've had my mk6 polo for a month now ! only just joined club polo! i wanted to know if the bumpstrips on the side of my car are stuck on or if they are attached by another way? can anyone help?
  • Replies 10
  • Views 1.7k
stuck on, but have locating pins into the body :(
So you can't just whip them off, it's a whole side spray I'm afraid.
same as above
They will be stuck on by double sided tape and they might have locating holes behind them. you might have to risk it and take 1 off. If they are any holes behind, you can always stick it back on.
or you can take my word for it, seeing as i've had mine off and there were holes for the locating pins.
there are 100% holes behind the strips if you take them off as panda said
and more importantly, remember they do a job...
cheers guy i was debating weather to get them colour coded or taken off looks like colour coding it is cheers guys! anyone know a rough price on colour coding al the bump strips?
in that case anyone know a rough price to colour code them?
if i where you pal i would whip them off and paint them yourself, youll find the colour code in you boot under the carpet.
if the finish is as good as you had hoped you can give them a quick coloursand with 1800 grit ( wet ofcourse) and then njust give them a bloody good buff with some g6 compound or spend a bit longer with T-cut.
this way it will only cost you a few hours and materials!!
Keep them on same you getting dents form other peopls doors :?
Edited by LOGiCALX
