What To Do :s
Was about to go out today and remove my bumpstrips when i thought to myself that i knew both rear quarters had been painted. To be on the safe side i didnt remove any but then though to myself that maybe if i take them off and there is a lip it may flat out. I know they was only masked up and not taken off before the respray. How big of a lip should i be expecting too see?? should i just leave them on?? how noticeable will it be really. Obv I'm wanting to take them off but am a little worried as dont then want to have too stick them all back on. thanks
chris
  • Views 966
Both rear quarters?
Take off one of the rear quarter bump strips carefully so you still have the glue on it and take a look.
Use a bit of t-cut or similar to see if you can get a colour match.
If not, wap it back on.
its not the colour I'm worried about mate. its the fact there may be a lip. i dont think if i start too peel them back the i will be able to stick them back on though. not if there the same as rear badges :)
thanks
chris
A lip?
Unless you mean a lip in the paint due to the respray and the extra coat being higher then the 6n does not have a lip near the bump strips.
If it is to do with the paint - T-Cut would even that out with a good rub.
A lip?
yeah mate i mean like obv where there will be another coat of paint on the rear quarter but not behind the bump strip there will be slightly higher. so f you run your finger over it u will feel a lip where it hyas been masked up.
chris
You're talking like sub-molecular particles.
However, these WILL be layered up, if you are good with a cloth and T-Cut you can blend it in nicely.
Will take some elbow grease though.
