Gt Conversion
hi folks time has come to get rid of the bready gt time for a change.
head has just had a rebulit,fresh skim,stem seals,valves reseated,bolts,guides,headgasket vag.
new vag themo housing,new fuel pump,new sump,vag sump gasket,vag throttle body gasket,vag timing belt,new water pump,exhaust gasket vag,whole exhaust is brand new except manifold,new lamda sensor,all gt clocks,switches,stalks etc,refurbed dizzy,new rota arm,leads,plugs,vag oil filter,brand new gearbox assembly mount vag,air hose's oil breather pipes all vag,fuel pump loom,engine loom,interior loom,ecu etc.
the conversion is in my mrk2 bready been decked 70mm all round good clean shell.willl sell whole car or remove engine to sell.
for whole car i want 1000
for everything u need for the conversion 700 as i have easliy spent that on the engine in the last 3 months when it was gettin done.i have stacks of receipts for the parts mostly from vag.
i am based in perth,scotland.
i can have engine took out and put on a pallet for a couirer if anyone needs that done.
if anyone wants to p/x with some nice wheels for a 6n2 polo let me no what u have got.
if some really really nice wheels come up i will straight swap but wheels would have to be good condition.bbs or something like that
cheerz for looking greg
  • Views 423
pm'd
700 hundred for a gt conversion is very expensive even if its fresh rebuild. crazy for a 75bhp 1.3 engine!!!
i'll swap you my 2.0 16v engine for you conversion!!
