Thermostat!
thats the second time my thermostat has failed, it was stuck shut again. so car overheated and had to wait for my dad to bring me up an 8mm spanner to get the fucker out. :-( not happy!! so now shes just running without one! :x
  • Replies 25
  • Views 2.3k
Is that safe running without a thermostat?
Nope because it'll mean that the water is shut off from entering the radiator, when it gets too hot, to cool down and keep the engine cooled.
Hmm my temperature light came on the other morning, car wasnt over heating but guessed the thermostat must have been on its way out, so went kevin coopers and bought a new one, came out started the car and the light had gone off.. lol.. guess it just got stuck?
I know sod all mechanics but i guessed it was abit risky!
I'm certain that if you remove the thermostat, the engine is overcooled as the radiator is always in the cooling circuit making the initial warm up take much longer. Most thermostats fail in the closed position, blocking the radiator circuit and causing chronic overheating.
Running a bit cooler with no thermostat for a while isnt going to bother it though, its not ideal but will do.
Have you checked your thermostats are knackered in a pan of hot water? at the end of th day its a very simple device, its a wonder they ever fail at all.
no thermostat will constantly cool the engine, not allowing it to get up to temp
no thermostat will also make your fuel consumption stupid, when thermostat was gone on my mk4 it ate half a tank doing 50mile...
Just realised what I wrote and meant it would be no good for the enigne to run with a knackered thermostat because it would never open
But if there was no thermosat how would the fans know when to kick in, wouldn't the water just get so hot that it would eventually blow a gasket?
temp sensor in the rad?
i drove round without a thermostat for about a month, i had no choice, couldnt get one even though there fairly abundent, anyway i had no problems at all, as far as I'm aware the water constantly flows around because theres nothing stopping it, it took a while to heat up obviously but eventually it did, as for fuel consumption, i was getting 400miles to a tank from a 1.4 6n so i wouldnt worry about running without one, the only thing that was a bit of a ball ache was that the heating took ages to heat up. but as mentioned that was due to the engine not heating up quickly...
please disregard everything he said above, it is currently winter, so your car will never get to temperature, it will constantly think it is cold and over fuel.
If your car does get to temperature in traffic etc, drive more than 500 yards and it will be cooled again.
Run with no thermostat, your fuel consumption will go through the roof
I'm not asking if it was safe to run without a thermostat! lol, just saying its the second one that is fucked in space of 4 months.
yeah we drifted off topic, well once is bad luck, twice is bad luck, 3 is a problem!
have you taken it out and played with it in hot water?
*images of him in a hot tub drinking champagne and opening thermostats lol
Oh your right actually, sorry i was lieing just for the fun of it...as if.....
...Please disregard everything he just said!! what i just told you was all true and i was driving this car during last winter when it happened to me, and last winter was a dam site colder than it has been this year so far... and as for never getting to temperature, thats a load of sh*t, your car WILL get to temperature, granted it wont stay at FULL running temperature for a long period though, and did i say at any point during my post that it would STAY at running temeprature so chill out and dont make out as if I'm talking bull, fuel consumption MAY be affected but from my own experience i was still getting 400miles to a tank so i cant say thats any different from what i normally get with a thermostat
so your telling me you were getting about 50mpg, on a car without a thermostat?
its a serious question, I'm asking?
but yes apologies for drifting off topic, first time mine went i left it in, and i had to drive home with the heating on full blast in the middle of summer so it wouldnt overheat, not pleasant, girlfriend wasnt too chuffed either
dont mean to sound like an arguement starter, i just dont appreciate it when i try and give advice and people make it sound like I'm lieing... so apologies again
serious answer is yes, i dont particularly like driving fast, and becasue i knew there COULD be a fuel consumption issue i was being extra cautious lol, changing gears early, not too many revs etc, i personally was surprised too
i still question the figures tbh
50mpg is hard enough as it is with a fully working car
but anyway!
It is usually the housing that breaks on the 6n's thermostat, not the thermostat itself. The plastic part which the needle pivots against snaps off causing it not to open as it has nothing to push against.
did this cure your overheating/running warm blindy? mines doing this atm, cant change the thermostat as some bast rounded one of the bolts off so i need a complete new housing
well i noticed my temperature was creeping up so pulled over n felt a few of the hoses leading to and away from the radiator and the engine, realised it could be the thermostat so put the heater on full and wound down the windows lol, worked a treat, i had to travel 110miles to get back home too n it didnt overheat or anything, me n my gf just got a bit warm thats all lol
i ment when you took the 'stat out did it sort the overheating lol
oh sorry, yea it did, as water was constantly flowing so it doesnt get chance to overheat, not ideal situation but if you need you are car for work etc then its all you can do
