6n Front Top Mount Nut Size
I need to get some spanners tomorrow so I can do the front top mount but can't remember the size of the nuts
I have some memory it being a deep 21mm one needed?
anyone able to confirm?
Edited by goose
  • Views 2.7k
allright buddy, i fitted some coilovers to my olop the other day and from what i can rember yes it is a 21mm
cool, thought it was, just wanted to make sure
cheers!
You'll be lucky to get a swan-neck in there,i use a spark plug socket and get a wrench on the hex built into it. You can then get your long 7mm allen key bit in the top.
I always thought they were just called Swan Neck Spanners?
If your stuck for a 21mm then then 13/16 will fit.
I used this only yesterday and actually think the nut is 13/16 rather than 21mm.
ok cool, was unsure whether a spanner would fit it there from past experiences so will try out the spark plug socket aswell :thumbsup:
what mikeyMK says is spot on i've fitted loads (30+) suspension and coilover kits on dubs and the 21mm plug spanner (socket) is the best option with the 7mm allen key in the top of the leg.
