Weight Of A Stripped Mk2 Breadvan.
helo
not sure when to put this but hope here will do.
basically I'm going to build a fast road/track toy mk2 breadvan
I'm going to make a wooden stand for the car to sit on while i build it.bit like a table but with castor wheels on the bottom
the car will be completely stripped no engine/box/interior.
so i basically need to know the rough weight it will be so i can order some castor wheels which are strong enuff to support if and wheel it about safley.
also the standard weight aswell thanks
max
  • Replies 11
  • Views 3.3k
I weighed an utterly bare bollock mk3 shell in the other week, I'll find the dockets and let you know what it went in for if I've still got them, but put it this way, 3 people could lift it easily and 2 bread
Think Haynes lists mk2 kerb weights, but I haven't got mine with me.
ok if you dont mind that would help alot.
According to the instruction manual supplied in '88,the 1.0 weighed 730kgs and the 1.3 weighed 750kgs.
How the 1.3 was 20kgs heavier,I've no idea.
More air in the cylinders? :p
5 speed box would add a little, bits and peices that CLs had that C's didn't. Can't really see what else TBH.
so how much do we reckon the engine box wheels and suspension are all going to weigh????
500kg? i have no idea.
300kg for the weight of a bare shell? do u reckon that sounds about right?
Can't find both dockets (car went in in the back of the van in 2 trips) but I'd say with all panels, 300kgs is about right. Probably about the same for the mechanicals.
ok thanks looks like to need to get some castors which handle upto 100kg each
I use some bread dollies, available from behind any supermarket ;)
hmmmmm.would save me buying some....but bread isnt very heavy lol need some for frozen pea's
4'll do it easy. We found a fairly complete G40 tends to bend a single one.
awsome.save me buying them.il be off to a supermarket soon then lol
