Removing Windows - Mk3
Hi all, my sisters written off mk3 has a set of green factory tinted windows- just wondering if it is easy enough to swap her set over to mine and put my non-tinted set into hers?
  • Views 1.4k
Depends what you mean by easy. Its not an enviable task,but its more time than anything.
The doors are easy enough. The back windows are easy to get out if you just work the seal along the top on the inside,then carefully and evenly push out like its on a hinge. Not so easy to fit,though - tedious and fiddly,even with Fairy liquid and seal hooks.
The tailgate is bonded. Good luck with that.
haha! ok i think i'll leave them as they are. thanks Mikey,
haha the rear windows are easy just run rome arround the rubber
they're all easy except for the tailgate window which to be honest, I wouldn't even bother trying with. It's bonded in and very difficult to remove without breaking it. As for fitting the rear side windows, put some strong string into the seal and spray a bit of wd40 round it. Then get a mate to put the window in place from the outside and push it against the car while you pull the string out from the inside. As long as you use decent strong string so it doesn't keep snapping then it's fairly simple.
If you are swapping the windscreen, best thing to do is to cut the seal with a sharp stanley knife and get a new one otherwise you'll probably just end up breaking the screen as they wont bend.
really easy to fit windows and remove just use wooden pegs to remove windows so no need to cut any window rubbers and get some one to help on the outside when refitting my mrs can fit widows nothing to it, the rear bonded window is a different matter though,
why dont you do the easy thing,
by the car back of the insurance company
(they will prob want pence for it)
pop all the glass out for when you need it,
instead of pissing about trying to cut the glass out the tailgate,
just pop the complete tailgate off untill needed,
then get a friendly screenguy to do it for cash after hours.
people make it out to be so much worse than what it actually is.
