Rear Wiper On 6n2
I've got a 6n2 haynes manual and it says lift up the wiper arm and there should then be a nut there, undo the nut and then the wiper should come off, but i cant find the nut
I'm guessing that method is for a 6n ?..can anyone tell me how to take the rear wiper off...wanna de-wiper the back
cheers for any help
Sonic
Edited by SoniC6N2
  • Views 761
Almost there. Lift the plastic cap from the other end ie not the wiper end (it flips up). Remove nut. Pull unit out. You'll need to remove the plastic fascia on the inside of the tailgate (2 torx bolts inside the handle recesses and prise off).
Marvel at now not being able to clear the rear screen.
