Polo Locking Problem
Help please! I'm fed up with climbing in through the car boot because the door locks won't work.
The keys just rotate on both doors, so I guess somebodys tried to force the locks..
I've had a look at the Haynes Manual and it says that for my model (98 Mk 4) I'll need a special VW tool to reassemble the freewheeling mechanism.
Is it possible to buy the tool cheaply or fix the locks without the tool?
Or must I pay VW prices (ugh!)
  • Views 689
might be the paddle has snapped... altho bad luck to happen in both doors. do a search there are loads of posts on fixing it. basicly there is a little metal padel between the barrel and lock mech, and it snaps. you can buy a replacement easily and cheaply, or bend a bit of coat hanger... like i did!
2 years later still working. pikey
